headlight recipe
Posted: December 3rd, 2004, 4:02 pm
by MarkMoore
what's the temp(and how long) i should cook my headlight in the oven in order to be able to pry off the clear plastic housing????
Re: headlight recipe
Posted: December 3rd, 2004, 8:09 pm
by Taras
Posted: December 4th, 2004, 9:17 am
by MarkMoore
thanks, so what type of sealant do you use to put em back together?
Posted: December 4th, 2004, 12:22 pm
by hgallegos915
I used clear permatex silicone on my civic projectors and it woprked fine..not sure on these stock headlights? they appear to use some grey silicone sealant.
Posted: December 4th, 2004, 12:40 pm
by jschrauwen
OMG!!! Taras bakes too. LOL
Posted: December 4th, 2004, 5:07 pm
by Taras
Yeah John, you need a nice big commercial oven for that
You can just reuse stock sealant if you wish. Or go to a Nissan dealership and ask them about Nissan Taillight sealant. It's heat resistant and made from proper Butyl Rubber compound. I have a Nissan Part# somewhere if you wish.
Posted: December 9th, 2004, 7:12 am
by mxmaz
I polished the crap out of the outside of my lights, then i decided to do the inside using the oven method. Didnt make a very noticable difference, i'd say 99% of the yellowness was taken care of by doing the outside of them. It was a real PITA to do, so i wouldnt recommend doing it. I just used black silicone to reseal them.
<small>[ December 09, 2004, 06:13 AM: Message edited by: mxmaz ]</small>
Posted: December 10th, 2004, 2:00 pm
by MarkMoore
mxmaz, i concur... there was a little bit of junk in my headlight, but not enough to make it worth the time... i havent put 'em back together yet-- i'm dreading that... might try that "special edition" or "limited" look posted in the FAQ section
Posted: December 10th, 2004, 3:42 pm
by Taras
You know guys you do not have to take your headlights apart to clean inside. You just use a solution of distilled water and isopropyl alcohol. Well, first water a drop of mild soap, then 4:1 water/alcohol. Rinse and air dry.
Posted: January 12th, 2005, 12:17 am
by reprobation
Tara, I never really thought about that... alittle bit of doluted alochol probably would work perfect..... i might just try that tomorrow
