The photos are, in order, low beam only, high beam only and both low / high at the same time.
Civic Projectors Light Output
The photos below are of the Civic projector lighting mounted in the car and 8 metres (25') from the wall. They look a bit yellow but the actual light is whiter than it appears.
- millionflame
Re: Civic Projectors Light Output
Much nicer cut-off than I thought they would produce.
~ Millionflame (94 GS 120K)
