Hey guys,
I just subscribed to this bulletin board this evening and please forgive me if someone has already asked this question.
I was just wondering if any of you guys had have the problem with the MX-3's headlight, tail light switch.. Where it's broken and wont turn on the head lights or tail lights. I was wondering how hard this would be to fix? Or where I could get the best price for the part I need. I've taken it to a electerical shop down here in Portland, Oregon and they wanted to charge me around $300.00 dollars to fix the damn thing.. I'm thinking thats a little expensive to fix it. Anyways thanks for listening and I hope to hear from you guys.
Headlight/Tail light switch
Snowboarder3185
Thanks,
Cory Zearing
Cory Zearing
Re: Headlight/Tail light switch
I had a problem with just the taillights not working. It ended up being the column switch. I removed the switch, filled it up with WD40 and its worked ok ever snce.
The switch mechanism can be removed quite easily - its a seperate part to the lever but you need a 90 degree ratchet Philips head to get it out. Maybe you should try this first before forking out any $$$.
I was quoted about AU$150 for a new switch from an auto electrician who was going to get it from Mazda. Said it was a stock item.
<small>[ October 04, 2004, 01:40 AM: Message edited by: Grants ]</small>
Yep, I had the same problem with mine when I bought the car... It was the column switch.
I had to remove the switch and then sand the contacts to get it to work.
Also - make sure you disconnect the battery! I blew a fuse whilst trying to be a smart *** !
This is a really common problem, my friend's MX also had this problem when he bought it. Bad design.
Racing
\Ra"cing\, a. & n. from Race, v. t. & i.
The alchemy that turns base metals into heat, noise, power
and motion.
http://www.cardomain.com/id/storm99
and motion.
