big electrical question
AllisMitchChalmers
where would i find the place where i can hook somethin up where it will come on when i turn on the ignition. Or would i have to ghettofy it?
Re: big electrical question
Under the fuse box is a bunch of wires going into a green plug. At least one of those come on with the ignition. You'll need to poke around with a voltmeter or test light.
You don't say what you want to come on - make sure it won't overload the circuit. You may need to use a relay and it's a good idea to put in a fuse.
AllisMitchChalmers
thanks
