lighting...
Kokiriwave
lighting...
Post by Kokiriwave »
I know this has been revisited before again and again, so don't blow a fuse
I went out and got a neon light with the ciggarete adapter....I cut the adapter off and exposed the wires...I connected the wires to the power supply for the ciggarate lighter..
This in my opinion is a pretty crappy setup and I'm looking more information on how to connect it to the dimmer so i can connect it to a REAL power source that won't keep it on everytime the car is on.
Please post with specific details including where/what color/ and how to connect the wires.
If all goes well I'll take pics of the finished product and retrace my steps in order to make a complete write up.
Any and all help will be appreciated. :froggie_red:
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
Kokiriwave
Re: lighting...
Better idea...
Can i just run wires from the battery directly into a swtich which then run into the neons?
Think this this will work for 4 neons...I'll give it a go.
I want MAZDASPEED!
Taras
Re: lighting...
Post by Taras »
Why don't you hook them up to the light that light's up cigarette lighter. This way it will ne on when your parking lights are on.
Taras
'92 GS Gray ZE
'05 Gixxer 750
MxWest VP
www.mx-west.com
m92_MX3
Re: lighting...
Post by m92_MX3 »
i got a switch, and i mounted it where the lighter was it works good, i did it because i got a ticket for the neons being on so i put the switch in so i could relize it better
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
Kokiriwave
Re: lighting...
ok this is what i did..
I hooked my light to ciggarete power source with a switch.
It works perfectly.. Now i just need to custom fit the switch next to the lighter and i'll be set...
I'll take a pic of the finished product...
Question: How many lights can i hookup to the ciggarete power source?
I want MAZDASPEED!
