Stereo
Posted: May 14th, 2004, 9:47 pm
by duane
I hooked up a pioneer system in my mx3 and i have problems with my dimmer switch but i found out it was just wires hooked up wrong. But i have a memery problem in the stero because when i shut the car off and start it again the stereo dont come back on like its spose too. Any ideas whats wrong ???
Re: Stereo
Posted: May 15th, 2004, 1:48 pm
by DJsMX-3
You have 2positive wires going to the stereo,a constant 12V and an ignition controlled 12V...
Maybe you mixed them up or only used the ignition 12V to power your stereo
you should connect the constant 12V to memory back up of your stereo,and the ignition controlled 12V to the other positive input of your stereo and everything should be back to normal
Re: Stereo
Posted: May 16th, 2004, 12:28 am
by BoOdOg
yeah that is more than likely what happen, everyone does it from time to time
Re: Stereo
Posted: May 16th, 2004, 10:24 pm
by Redlined
I am also having a similar problem. It has been the same since I have owned the car, there is a kenwood deck in the car and each time I start the car, or turn on the accessories, the CD pops out and I have to re enter the settings I want, volume... etc... is it the same answer?
Re: Stereo
Posted: May 23rd, 2004, 11:13 pm
by Redlined
somebody??
Re: Stereo
Posted: May 25th, 2004, 1:33 pm
by atx_mx3
yea..thats the same thing.
