RX-8 TAIL LIGHTS?
RX-8 TAIL LIGHTS?
Hi Mx-3 Riders and not. Just wondering if anyone has any INFO on having the RX-8 tail lights swap to the mx-3. If yeah, please share your knowlegde...
Compact Gladiator
"Do not follow the path, instead; go where there is no path and leave a trail"
WWW.GEOCITIES.COM/NEWFLOW81
Re: RX-8 TAIL LIGHTS?
they are not even close to the shape of the mx-3 tail lights
Black '92 GS - Pacesetter QuickShift w. SRD Extension rod Bushing + bronzoil - Top Speed Pro1 exhaust - Hotshot style headers - GTS coilovers - 18" ADR Sokudo gunmetal, f+r strutbar, floorbar & SRD crossmember
would be a total custom job and probably need rewiring as well as body work
- MX3-Freak
[quote]Originally posted by SIXPACK:
And if I'm totally wrong about your experience and access to materials, I revoke everything I just said
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
thanks for your comments. eventhough when I ask to share your knowledge was to obtain INFO on the swap already done. NO speculations or guess how it could be done...just hard facts from actual experiment...
Compact Gladiator
- atlantamx3
The answer you are looking for is:
NO-- It has not been done on an MX-3 before.
Therefore-- no one will be able to give you anything but specualtion about how it could be done.
A more realistic answer...
Compact Gladiator
I just did this reconstruction of what a mx-3 would see with rx-8 tail lights. Didnt like the results dough.
<img src="http://www.geocities.com/newflow81/mx3rx8.jpg" alt=" - " />
Compact Gladiator
Compact Gladiator
WHAT DO YOU THINK OF THE PICTURES?
AT LEAST I AM STAYING IN THE MAZDA FAMILY INSTEAD OF BUILDING A RETARD WITH HONDA FRONT LIGHTS OR TOYOTA TAIL LIGHTS.
Compact Gladiator
- MX3-Freak
Yes, but you could of used 6 lights...something that might look at tad bit better...
Car Meanins:
Car Meanins:
Mx-Flow, keep your "voice" down please. No SHOUTING.
- papa roached
and i better not see him every use civic projectors on his car
<small>[ September 04, 2004, 12:06 AM: Message edited by: papa roached ]</small>
I truly didnt mean to create the reaction I did nor pretending to be screaming. I just though of it and want to see some reactions. You guys with all does stars are the one that should be helping.
Compact Gladiator
