unknown problem
Dali
unknown problem
Post by Dali »
just driving home i came across the intersection and then no power, pulled over to the side of the road gave it gas and nothing, shifted through all the gears and nothing, wouldnt move. after trying for about three minutes of the car running the hold button began to flash. i shut the car off and back on no flashing hold light. let the car sit for about five minutes and back to normal, i had power in all gears. thanks.
1993 White gs klze.
hondah8er13
Re: unknown problem
Post by hondah8er13 »
sounds like a clogged filter... when was the last time that you did a filter and fluid change? also when your hold button flashes that means that your ecu has detected a serious problem with your transmission.. but mine did the same exact thing yours is doing, flashing hold light and everything... changed filter and fluid... works great... hope this helps
Zoom-Zoom
Return to “Transmissions”
