Sputtering engine.....check engine lights up !!
Posted: October 16th, 2004, 11:38 pm
Hey everyone,
I've got a 93 mx-3 V, 170K, GS......great little machine... although I've run into engine problems.
While on the express, the engine started sputtering, misfiring and coming to a stop, and the engine light lit up on the dash!
I've replaced the map sensor, no change.
I've replaced the distributor and rotor, the car now idles, but it will not go through the RPM's without eventually sputtering and shutting down....and the engine light lighting up.
I smell unburnt fuel coming from the exhaust, seems as though it's misfiring!
Anyone run into the same situation ?
