under the car
ZEmadman
under the car
Post by ZEmadman »
i was just curious how everyone does work under their car? jackstands, ramps, your own devilish device? what? im wanting to do more and more work to my car on my own but only have 2 jackstands and a cheezy jack. anyone have a unique way to work under their car?
RoundTop
Re: under the car
Post by RoundTop »
Jackstands are probably the cheapest.
A set of 4 will only cost about $30CDN if that.
fry_81
Re: under the car
Post by fry_81 »
i usually use jackstands or the shop lift at work :D which is a million times quicker
koreanmx-er
Re: under the car
Post by koreanmx-er »
lift at work, i usually just stay after and use it then , but if at home i use stands
sold the mx-3 , bought 04 gtp comp g , from the smallest v6 to one of the biggest 3800 s/c FTW
lakersfan1
Re: under the car
Post by lakersfan1 »
I'm ghetto. I use the jack out of the trunk for everything.
Grants
BANNED Member
Re: under the car
Post by Grants »
Floor jack and stands. Well worth the $$
Gro Harlem
Re: under the car
Post by Gro Harlem »
and get a good floorjack. Those "kits" that include 2 jackstands & a jack always include the biggest peice of crap jack you can get, and don't raise it hardly at all.
I Dunno what the cheapest price is for a good jack, but it is proably at least 100 bux. Mine was 300, its a 3-pump low-profile race jack and raises my car PLENTY high.
DONATE TO MX-3.COM
MX3-Freak
Re: under the car
Post by MX3-Freak »
I built my own ramps :welder: . Works for eeverything but removing a wheel.
Stock 1995 RS - Creek Blue
Car Meanins:
fry_81
Re: under the car
Post by fry_81 »
lol ya i guess you'd have to build your own ramps. i have ramps but when i went to use them i realized that these cars are far too low for ramps lol.
ZEmadman
Re: under the car
Post by ZEmadman »
i'll prolly end up just getting another set of stands and a better jack. thanks for the input fellas.
freak: what did you use to build your ramps?
papa roached
Re: under the car
Post by papa roached »
i just use stands and a jack, did my whole swap on stands
killerpickle
Re: under the car
Post by killerpickle »
You can buy ramps made for low cars. Ive seen them for just under 80 bucks. There a lot more gradual of an incline.
Tom Alexander
Dominicanchu_Nmbr1
Re: under the car
Post by Dominicanchu_Nmbr1 »
i use ramps and stands, but because of the incline issue mentioned, i raise it w/a jack first, then slide a ramp under the wheel and sit it down. works fine, and if you've got four ramps, you can lift the whole car that way. Works every time for me, and i don't gotta worry about a jack popping and the car falling on me...but then again, you'd have to be using a pretty crappy jack for that to happen.
-=[Irving A.]=-
de_sjiem
Re: under the car
Post by de_sjiem »
Just wanting to remind ppl that it can be really dangerous to work under a car that just has a jack under it... use axle/jack stands or a ramp or something more secure... jack stands aren't really that expensive... and also remember to use jackstands in pairs!!! I just dont want ppl to get hurt... :-)
