I was thinking about miata parts in comparison to mx-3 parts. I know we share alot of the same parts over the years so I figured I would see what wil fit and what MAY fit and post if for those who may want to try.
AC vent balls ( MAY fit the 94+ )
http://www.rspeed.net/miata/item.asp?dept=2&cat=13&prod=202-040
AC vent rings ( MAY fit the 94+ )
http://www.rspeed.net/miata/item.asp?dept=2&cat=13&prod=202-039
TT style AC vent rings( MAY fit the 94+ )
http://www.rspeed.net/miata/item.asp?dept=2&cat=13&prod=202-049
Door handle rings (MAY fit all years)
http://www.rspeed.net/miata/item.asp?dept=2&cat=13&prod=202-138
Chrome side markers (These SHOULD fit, since we use Miatas as clears side markers.
http://shop.store.yahoo.com/gomiata/ilmotchromsi.html
FAQ: Some new ideas for you guys.
Re: FAQ: Some new ideas for you guys.
The issue with the clear sidemarkers is only this, get only the lense, If you buy the housings as well, it will not fit, as the miatas housing curves out more and sticks out. If you get the miata clear lens, just get the lens and not the houseing (this info. is mainly for the front sidemarkers). I've also heard that the b6 miata headers will fit the b6t if you are doing the b6t swap, still might be clearance issues with the electric fans, but the phlanges and ports line up and fit according to jgstools.
-Mark Lathrop
1992 MX-3 RS-T
B6T with some goodies
1992 MX-3 RS-T
- Custommx3
- Site Administrator
Tom S has miata chrome handles. Im unsure what year,
but you can get them here.
http://www.miata.org/
I have them as well. They are 1999/2000 handles.
I think Miata rotors fit in a MX, not sure though.
later,
dee
later,
dee
'92 MIATA
'93 MX-3 BPT
'08 CX-9 AWD GRAND TOURING
'93 MX-3 BPT
Wow! Those vents look real good. This past weekend, using Krylon and chrome spray, I sprayed my rings and vents. Chrome rings, metalic blue vents. I'll hopefully have pics by next week.
<p>one
- monty73741
i used miata vent rings they fit......kinda....
you have to put some glue in & hold em there & tape it up till the glue dries..
Jason Danaher
Please Help Support MX-3.com
- monty73741
Jason Danaher
