Water in spare tire well
anvil82
Post by anvil82 »
I am getting water in the spare tire well, but I do not know how it is getting in.
Is this a common problem, and what could be the cluprit?
mitmaks
Re: Water in spare tire well
Post by mitmaks »
probably rubber gasket around hatch leaking somewhere
EvOmX3
Post by EvOmX3 »
yeah i got a pantload of water in my rear washer fluid area, it is quite a bit....so i cleaned it out with a shop vac, but i have also been getting water in my doors as in it leaks through the window....and messing up my speaks, i temporarly fixed it by putting plastic to cover my speaks...has this happened to anyone?
mitmaks
Post by mitmaks »
water always passes through doors when it rains etc. its usual, but if drain holes are plugged itll settle in bottoms of doors and theyll rust out, check to see if train holes are plugged up, theyre usually on corner of the door
lakersfan1
Post by lakersfan1 »
I didn't have any problems till I took the gasket around my spoiler off temporarily, then it started letting water in through the mounting bolt holes for the spoiler. It should stop again as soon as I get around to replacing the spoiler gasket.
