September drag board
Anyone still racing? I will be running at the track on this Friday, I will post my numbers then.
1)Ma-ZE ........12.10 @ 117.00 mph turbo I4
2)Rebek2k4......14.23 @ 102.63 mph turbo klde
3)Mx3man83......14.508@ 101.67 mph N2o klze
4)Schwankesmx3..15.76@ 89.30 mph b6ze
<small>[ September 18, 2004, 07:45 PM: Message edited by: mx3man83 ]</small>
My Cardomain site
My Cardomain site
Re: September drag board
Just went tonight with the turbo KL. The track is 5300 ft above sea level...
heres my best run:
60' 2.347
1/4 14.235
MPH 102.63
Mods: KLDE swap, T3/T04B at 6-7 psi built by myself, water injection, STOCK EXHAUST!!!
heres my best run:
60' 2.347
1/4 14.235
MPH 102.63
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- papa roached
this CRAZY for stock exhaust man
still 12.1 @ 117 for me. put a built head on the car last week. im waiting on my new intake manifold and a roll cage, then its back on the dyno. should be nice, new cams have a 406 lift, boost is ready to be turned up, and with the built head comes more rpms!
92 MX-3 RS,
Racing Mazda turbo kit. 451 WHP @ 25 psi
12.1 @ 117 mph w/318whp
http://www.cardomain.com/memberpage/652555
why are you running stock exhaust still? A turbo really needs to breathe.Originally posted by rebel2k4:
heres my best run:
60' 2.347
1/4 14.235
MPH 102.63
1992 MX-3 handed down to my sis
1992 MR-2 Turbo sold and missed
1995 Integra GS-R
1995 Integra GS-R
> 1.26- reaction
> 2.34 - 60 ft
> 6.74 - 330 ft
> 10.276 - 1/8 ET
> 70.07 - 1/8 MPH
> 15.76 - 1/4 ET
> 89.30 - 1/4 MPH.
> mod are as listed ....b6ze..magnacore 8.5wires...ngk id plugs...2 1/2''
> stright pipe....computer tunning...adva. timming..probe headers...rebuilt
> tranny
> with a .420 diff, tit.gears....ram intake.....nito drag
> radials......gutted....
> put me on the drag boards
> 2.34 - 60 ft
> 6.74 - 330 ft
> 10.276 - 1/8 ET
> 70.07 - 1/8 MPH
> 15.76 - 1/4 ET
> 89.30 - 1/4 MPH.
> tranny
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
> 1.26- reaction
> 2.34 - 60 ft
> 6.74 - 330 ft
> 10.276 - 1/8 ET
> 70.07 - 1/8 MPH
> 15.76 - 1/4 ET
> 89.30 - 1/4 MPH.
> tranny
> 2.34 - 60 ft
> 6.74 - 330 ft
> 10.276 - 1/8 ET
> 70.07 - 1/8 MPH
> 15.76 - 1/4 ET
> 89.30 - 1/4 MPH.
> tranny
> 1.26- reaction
> 2.34 - 60 ft
> 6.74 - 330 ft
> 10.276 - 1/8 ET
> 70.07 - 1/8 MPH
> 15.76 - 1/4 ET
> 89.30 - 1/4 MPH.
> tranny
> 2.34 - 60 ft
> 6.74 - 330 ft
> 10.276 - 1/8 ET
> 70.07 - 1/8 MPH
> 15.76 - 1/4 ET
> 89.30 - 1/4 MPH.
> tranny
Blah blah blah,,, can we link to the other list? =]
-torp.
I don't own a Mazda.
I got in about 5 runs in last night. I won all except the last one against an srt4 and the only reason I lost is because my car started doing the bucking thing I've been having trouble with lately, causing me to run an 18 something. I had previously beat the srt4 earlier in the night. I need to just take my car in have it put on the diagnostics.....something hasn't been right for about months now. I thought I had the problem taken care of but obviously not. One of my runs I did a 14.7 @ 102.7 mph. Its weird how I can do that, but I watch those stupid AWD turbo WRX's run 13's with a top speed of 99 mph. I want either AWD or drag slicks
My Cardomain site
My Cardomain site
Mx3man what are your 60' times? I cant get out of the hole either. at least I have a somewhat decent launch and pull 14.2 with your same MPH.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
Let's see, on my 14.5 run i did 0-60' 2.342. I ran 14.5 twice but i misplaced 2 of my time slips so im not sure of the other run. On my 14.718 @102.7 mph run my 0-60' was 2.794.
My Cardomain site
My Cardomain site
Found one of my time slips i thought I lost...14.508 @101.67 mph. 0-60' 2.5
My Cardomain site
My Cardomain site
Anyone got more times? Comments or feedback on anyones runs?
My Cardomain site
My Cardomain site
MX3man what launching rpm do you use? What technique? With a 2.2 or better 60' you should be in 13's with that trap.
Whats the elevation in tuscon? did you ever run without nitrous?
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
