b6t times????
schwankesmx3
b6t times????
hey guys give me ur b6t times ...i just want an idea of what to look for ..... this is what im puttin on the b6t..je pistons.. 400cc injectors ... t4 turbo.. gready bov..beefed up b6 tranny...turbo timer..hks cams and gears...udp...hks custom i/c...2 1/2 exhust tubing..let me know if i need nething else...thanks..
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
- Shady469
Re: b6t times????
what are you doing as far as engine management goes? you'll need something to compensate for those injectors(i'm @ -40% on the S-AFC at idle with 370cc injectors).
times: my best to date was a 13.9 @ 101. thats with the stock turbo at 13psi and not spraying the chiller kit. well, along with a good deal of work... check my sig for the website(mods on page 2). if you can track it and get it tuned correctly i would not be surprised to see you hit a mid-low 13 or even a high 12. Good luck.
<small>[ May 24, 2004, 04:21 PM: Message edited by: Shady469 ]</small>
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
schwankesmx3
Re: b6t times????
thankx alot i'll post my times when its all done im lookin forward to it and i'll be takin pic's along the way
