Page 1 of 3
updated images of my car *56k grab a cookie*
Posted: April 16th, 2004, 3:33 am
by marshmallow15
just some updated pictures. not trying to explain anything. i know there will be haters. any tips/suggestions to make the car look better since its goign under its second makeover? im not trying to make it into a showcar btw.
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 010019.JPG" alt=" - " /> rebuffed and redid headlights
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 010038.JPG" alt=" - " /> old pic showing the painted engine bay
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 230136.JPG" alt=" - " /> car isn't running!
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 040099.JPG" alt=" - " /> satin black mazdaspeed steering wheel
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 030053.JPG" alt=" - " /> rjs red 5-pt harnesses
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 030057.JPG" alt=" - " /> interior shot
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 030060.JPG" alt=" - " /> currently removing a/c system
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 100091.JPG" alt=" - " /> is this a safe mounting point?
Re: updated images of my car *56k grab a cookie*
Posted: April 16th, 2004, 3:36 am
by marshmallow15
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 100098.JPG" alt=" - " /> another interior, PS seat is going back in.. removed it for room to work
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 100100.JPG" alt=" - " /> notice the modified turnsignal
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 100102.JPG" alt=" - " /> another view
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 100111.JPG" alt=" - " /> replacing roof with a painted carbon fiber roof
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 100112.JPG" alt=" - " /> heater control panel will be replaced with a carbon fiber switch panel.. swithces for fuel pump, secondary injectors, nitrous, etc.
Posted: April 16th, 2004, 3:38 am
by marshmallow15
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... 100113.JPG" alt=" - " /> sideskirts. came out blurry, night shot wouldn't come out right
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... skirts.jpg" alt=" - " /> old skirt pic
<img src="
http://rs6kc.swc.cc.ca.us/~b2520102/sit ... kirts2.jpg" alt=" - " /> skirt pic from in garage. car was towed by friend.
Posted: April 16th, 2004, 5:41 am
by MikeUK
I like the skirts, nice and smooth looking. Are they off another car or did you make them?
Posted: April 16th, 2004, 9:55 am
by Shady469
Holy stripped interior batman!! j/k i'm not gonna hate b/c mine looked like that for a while too. i had to put some stuff back in b/c it was just too loud inside the car. i mounted my harness to the bolt holes where the back seat belts bolted up(on the seat portion not the strut tower).
a few things: i like the taillights and the side skirts, they are very clean.
however i liked the turn signals better blacked out. why did you remove the instrument cluster? i also had no idea your car was an auto.
there is a pic on my website(kinda sorta) check my sig.
ps. i love the MS steering wheel.
Posted: April 16th, 2004, 11:39 am
by atlantamx3
Not my style, bro.
Love the side skirts overall outline, but they are kinda flat.
Whatever floats your boat!
Posted: April 16th, 2004, 12:21 pm
by SE-Man
RICE!!!!!
J/K.... hehee. I think it would look better externaly if you had a fron OE lip and a custom rear Lip. Internaly are you goin with a striped "race" look or a "stock W/ Extras" look?
If you go with a striped look keep the same paint. If you go with a stock w/ extras look, It'd look cool to make Fiberglass raplacement peces for the interior.
<small>[ April 16, 2004, 11:22 AM: Message edited by: SE-Man ]</small>
Posted: April 16th, 2004, 1:02 pm
by mitmaks
looks like you got big project going on there, well looks like you got it though
Posted: April 16th, 2004, 3:25 pm
by cjthor
I would bolt your seatbelts down on the floor where the lower part of the belt bolted to. I think it is safer that way. <img src="
Is that a copper pipe for a rear strut brace?
<small>[ April 16, 2004, 02:27 PM: Message edited by: cjthor ]</small>
Posted: April 16th, 2004, 3:40 pm
by atlantamx3
Yes, Do that only if you want to have your back broken if you crash. Mounting your shoulder belt to the floor behind you will cause your back to compress and break if you crash. Lap belts can be mounted to the floor, Shoulder belts should be on the upper rear strut mount like you have it, or on a cross bar in a roll cage.
Where you have it mounted now is more safe than the floor. If you think about it, the rear seatbelts are mounted at the top of the rear strut tower as well.
However, I would use the same bolt that the rear seatbelt uses instead of an upper strut bolt.
Posted: April 16th, 2004, 4:51 pm
by cjthor
Hmmm. I wonder why the shop I took my car to get the seat and belt installed did it that way then... <img src="
http://images.cardomain.com/member_imag ... 1_full.jpg" alt=" - " />
Posted: April 16th, 2004, 5:03 pm
by marshmallow15
actually i think jarid's setup is fine because of that rollbar, since the harness rolls over that bar its actually perpendicular to your back, yet secured by the bottom. that way if you crash, the rollbar will prevent that compression that can really mess up your spine. but yea i decided to mount it at the OE rear seatbelt position. i believe the rear seat belt bracket was originally mounted to the strut bolt from the factory.
yes it is stamped copper. very ghetto. im replacing it with a corksport unit however and going to wrap the center of both strutbars with cfiber, mostly for looks.
mikeuk: the skirts are actually the mazdaspeed skirts for my car, and i recently wrecked it from a curb, so i repaired it and molded another skirt from an rx-7 that i modified to fit it. was aiming for the sleek OE look.
shady: the turnsignals were blacked out, but faded because i didn't clear coat them. i might retint them with just one layer and not too dark that i had before. they actually look darker in person than in that pic. i guess its because of the flash. oh and remember my old instrument cluster needles broke, which is why i have the digital speedometer in my pillar pod? well im putting in a new cluster with a speedhut cfiber bezel. just haven't gotten it yet.
se-man: actually the OE v6 front spoiler is in my plans for this car. just i never got to purchasing one yet. oh and i'm going for the stripped 'race' look. not too many extras aside from racing seats, the harnesses, rear strut bar, aluminum fuel cell in the back (yes that means pump and inline filter will be back there too), rear trunk battery relocation, mazdaspeed steering wheel, lcd headunit, srd ebrake, greddy shift knob, and the gauges. pretty much everything else will be stock or stripped.
thanks for the suggestions guys.
<small>[ April 16, 2004, 04:08 PM: Message edited by: marshmallow15 ]</small>
Posted: April 16th, 2004, 5:08 pm
by atlantamx3
The difference on yours Jarid is that it is going over the roll cage.
If the angle of the seatbelt from the anchoring point to the seat is MORE than 45 degrees, it is very dangerous and should be done right. In case of an accident, it will compress your spine, and more than likely break your seat.
Yours should be okay Jarid because its going over the roll cage and therefore making the angle less than 45 degrees.
Posted: April 16th, 2004, 6:32 pm
by Nd4SpdSe
What was teh turn signal modified for?
Posted: April 16th, 2004, 7:52 pm
by kuruption1983
hmmm, to be different.
