Kfze Installed: easter bunny was good to me
ITS FINALLY IN!!!!!
Thanks to everyone in Moca AND Barry Clark for all the help this weekend.
This motor is fast and fun and has Zero problems or CEL lights, Thanks to shawn getting me the kfze ecu.
not all mods were added there is a slight modification needed to be done to have a kl IM to work on the kf, but im gonna wait and have my KL IM fixed up a bit.
And for you viewing pleasure:
before:
<img src="http://images.deviantart.com/i/2003/15/ ... _mx3_7.jpg" alt=" - " /> incase pic doesnt appear
After:
<img src="http://www.atlantamx3.com/moca/brian/kf ... G00016.JPG" alt=" - " />
<img src="http://www.atlantamx3.com/moca/brian/kf ... G00010.JPG" alt=" - " />
<img src="http://www.atlantamx3.com/moca/brian/kf ... G00028.JPG" alt=" - " />
<img src="http://www.atlantamx3.com/moca/brian/kf ... G00040.JPG" alt=" - " />
<img src="http://www.atlantamx3.com/moca/brian/kf ... G00049.JPG" alt=" - " />
<img src="http://www.atlantamx3.com/moca/brian/kf ... G00052.JPG" alt=" - " />
<img src="http://www.atlantamx3.com/moca/brian/kf ... G00039.JPG" alt=" - " />
More pics to come!
<small>[ April 12, 2004, 11:16 AM: Message edited by: Mnemonic ]</small>
before:
After:
More pics to come!
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- Custommx3
- Site Administrator
Re: Kfze Installed: easter bunny was good to me
Anytime, glad to know I could help,
where did you order it from?
i got it local from BJE (best japanese Engine)for 650 but when i got it, it wasnt in the best shape(looked like it had been getting plenty of oil but never changed, if you look in past threads ive posted you will see what it originally looked like and what i have done to it, it wasnt that clean when i bought it
<small>[ April 12, 2004, 11:09 AM: Message edited by: Mnemonic ]</small>
ITS ABOUT FARKING TIME!!!!
Let us know the overall results once you start driving it regularly
. Looks nice and clean! My motor was pretty clean too, but not like that!
DONATE TO MX-3.COM
DONATE TO MX-3.COM
nothing that carb cleaner and elbow grease wont clean
eh,
it looks alright...
![Pimp :pimp:](./images/smilies/pimp.gif)
Mnemonic, have you put in the KL manifold on your KFZE? How does it goes? I have a spare KLZE manifold, and thinking of putting it on my Xedos 6 KFZE, but not sure if it worth the effort.
Rgds,
omar 626_KLZE MX3_KLZE Xedos6_KFZE
Rgds,
- Custommx3
I wouldnt recommend that. IM putting a KL IM on my KFZE this weekend. The KLZE IM has square runners, the KFZE has round runners, depending on the version you have. If you have the same model engine Jnumonik and I have, yuo have round ports on your heads.
- papa roached
Whats different than putting a KL-ZE curved neck on a KL-DE? Guys over at PT do it all the time and they are putting the square runners on a round intake port head and they get gains.
- Custommx3
they SAY they get gains... but Ive personally never seen the dyno results, if they exist.
put a square over the round hole, and u get restrictions in airflow in the corners.
<small>[ October 12, 2004, 11:33 AM: Message edited by: Custommx3 ]</small>
Probably u rite. My KFZE head should be same as yours as it is in Eunos 500 model (Xedos 6 JDM). But do update us how it goes with the KL03 manifold on KFZE. I installed KLZE TB on the KFZE, but did not feel any different at all. Totally opposite if compared to putting 64mm TB on my 626 KLZE.
>I wouldnt recommend that. IM putting a KL IM on >my KFZE this weekend. The KLZE IM has square >runners, the KFZE has round runners, depending on >the version you have. If you have the same model >engine Jnumonik and I have, yuo have round ports >on your heads.
- mitmaks
ive got blaster 2 coil on my charger too, hows it working on ur mx3?
its not the motor is dead due to water, probably getting a klze and putting my cams in it and parting everything off
