Well 3 out of 4 shock absorbers are leaking. Need to find replacement but so far prices have been so far 100 GBP each! going to do all 4 anyhow, does anyone know of a cheaper brand or supplier many thanks!
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
got a quote for full set of Bilstein @ 305.00 GBP might sound like a stupid question but do the springs have to be released to replace the dampers if so is it worth replacing the springs for lowered versions? just a thought.
You can get bilsteins ?
They are great I tried to get them and they said they weren't available for our cars ?
Whats the deal ? Does the Euro version have different mounts or something ?
Thanks
Kris
93 Kandy Tangerine Mx3 GS-DE
05 Saab 9-2x (Wrx power plant)
02 Subaru Impreza OBS
05 Subaru forester Xt - sti mods
04 dodge ram - toy hauler -FOR SALE
& Lots of Toys to haul
Will double check with the supplier to re-check his listings, whatever it is a strut or a shock it is leaking. Even in the dryest of weather the bottom part of the strut around the suspension ring theres a wet greasy dirt feel that never dies out unlike the dirt build up found behind the wheel arch for example.
