zx2 conversion
jonny_boo
zx2 conversion
Post by jonny_boo »
i just read about the zx2 suspension conversion, will this work with a 94 rs, and if so should the springs used be specifically for the ford zx2, or the mx3, im assuming zx2 but still need advice before i spend too much cash.
babyblueMX3
Re: zx2 conversion
Post by babyblueMX3 »
you can put mx-3 springs on zx2 struts...just don't now if the struts will fit the rs tho
RIP 400whp ZE-T MX-3
mykel78
Re: zx2 conversion
Post by mykel78 »
I wanna know the same thing. Can I use the ZX2 struts with my factory springs. Where I live it's rather unwise to lower an already low car. The half inch sounds great, but with factory springs??
If not broke - don't fix, modify. If broke - fix it right, and make it better.
babyblueMX3
Re: zx2 conversion
I have the zx2 struts on my car..didn't lower half an inch extra at all..then I ask myself why?..well it's the spring that give you the height of the car..the strut follows the spring..so yeah maybe the zx2 strut is shorter but it doesn't give you an extra 1/2" drop :shrug:
my friend's gs is actually lower than mine and he has kyb..btw we both have suspension techniques's
<small>[ October 02, 2004, 01:21 PM: Message edited by: babyblueMX3 ]</small>
Yoda
Re: zx2 conversion
Post by Yoda »
The MX-3 and ZX-2 are both built of the 323 chassis. Mechanically whether you have a MX-3, ZX-2, Escort, Sephia or (BG)Protege you are in reality just driving a (BG)323. This is why all replacement strut for the MX-3 have the same P/N# as the '90 323 Hatchback. The only difference is that on the ZX-2 struts is Ford uses the larger diameter front thrust bearing of the Probe which requires modification to the MX-3 upper spring hat.
mykel78
Re: zx2 conversion
Post by mykel78 »
But. Will it work with stock springs??
Marlon
Re: zx2 conversion
Post by Marlon »
yes
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
Custommx3
Site Administrator
Re: zx2 conversion
Post by Custommx3 »
Moved to suspension...
mykel78
Re: zx2 conversion
Post by mykel78 »
Thank you Marlon!!! :2thumbsup: I've been wondering about that for a long time. Thought I'd have to try it out, but didn't want to break anything in the process
Thanks!
Sam Baker
Re: zx2 conversion
Post by Sam Baker »
haha.. trailing off of what babyblue said, before i installed the zx2's in my car, i measured the heights compared to kybs, and the kybs are shorter half an inch than the zx2's! maybe it's that their higher, i duno really.. but either way stock springs will work on them. also, the 94 models have different strut towers than the 93's, i've found, but both seem to combine ok :welder:
92 Autozam AZ3
