Any big deal if I buy non-ABS struts for my 93 GS that has ABS? Has anyone done this so they would be able to explain what needs to happen,
thanks
ABS v non-ABS Struts
Re: ABS v non-ABS Struts
The only difference is that the non-ABS struts don't have the mounts for the ABS sensors. You can have the ones from your stock struts cut off and tacked on to the same locations at the base of the new strut bodies.
