If I wanted to lower my car would I need to get new struts and lowering springs.....if so what do you guys suggest and how much do u think it would cost for the parts + work done by a shop. Thanks in advance.
P.S. Also what is the difference in just getting lowering springs instead of getting Ground Control Coil-overs? Would I need new struts for GC
New to this
- dj inferno
Re: New to this
you don't NEED struts if u get lowering springs or coilovers... i personaly went with the lowering springs... they are 170$ plus S&H at www.nopi.com best i found... and if u want struts... search... theres alot on the board about them. but yah... search. it will help.
Re: New to this
Ok so if I buy new struts with lowering springs will I have to change anything else? If I do this I plan on buying tokico struts with the susp. tech. springs....lemme know if I will need anything else and is 507$ fairly priced for everything?
Re: New to this
My shop usually charges $200 to install a set of four springs and shocks on the car. This is just for the labor.
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
