rear strut bar..
Low3-XM
rear strut bar..
Post by Low3-XM »
all i can find is front on ebay... where can i order a rear... ?
babyblueMX3
Re: rear strut bar..
Post by babyblueMX3 »
i beleive corksport and ractive has it
RIP 400whp ZE-T MX-3
mx3TT
Post by mx3TT »
CorkSport has one. I got it for christmas, I didnt install it yet though.
Chris
MY MX-3 PICTURES
MX-3.com's online store - SUPPORT MX-3.COM
Low3-XM
Post by Low3-XM »
This front or rear... Strut bar
mx3TT
Post by mx3TT »
Looks like a front to me. But I hope they are not showing the actual product because that bolt pattern will not work on front or rear.
Chris
MY MX-3 PICTURES
SIXPACK
Post by SIXPACK »
dont buy the strunt bars from ebay. they are crap quality and some even dont fit properly. I recommend you buy one from corksport
/SIXPACK
Black '92 GS - Pacesetter QuickShift w. SRD Extension rod Bushing + bronzoil - Top Speed Pro1 exhaust - Hotshot style headers - GTS coilovers - 18" ADR Sokudo gunmetal, f+r strutbar, floorbar & SRD crossmember
babyblueMX3
ebay only sells the front strut tower bar and yes it's a crappy bar
check this is the rear strut bar from ractive..prolly not the picture shown...check the link last one on the bottom http://www.nopionline.com/index.cfm?fuseaction=dspparts&vL1ID=0&makeid=220&modelid=108&catyear=1992&catid=0010&pcid=472&vTitle=1992%20MAZDA%20MX-3%20Suspension%20Strut%20Tower%20Ba r%2FTie%20Bar&vaffid=0
Mnemonic
Post by Mnemonic »
i got the ractive bar looks good but as most can tell you it is and isnt an easy install, personally i consider my car a 2 seather so No more rear seatbelts
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
atlantamx3
Post by atlantamx3 »
Well Brian, we took the easy way out on your car by just removing the rear seatbelts instead of doing it the right way.
I still have mine, and you can keep yours-- it just requires some minor cutting with the Dremel.
~Perry
Please visit
http://www.mx3-atlanta.com
tonguefreek
Post by tonguefreek »
check this place i got mine there it fit great only minor cutting is needed on the seat belt mount http://www.carmedia1.com/index.html?target=front.html&lang=en-us
Low3-XM
Post by Low3-XM »
cuttin the plastic away right ???.... did it make a big differnce ??
Mnemonic
Post by Mnemonic »
plastic and some metal,
atlantamx3
You have to cut about 1x2 inches out of the plastic, and 2x3 inches out of the metal seatbelt bracket.
Those are rough "guesstimates" though.
~Perry
Please visit
mx3TT
Post by mx3TT »
Yeah Perry that seems about right. I installed my CorkSport rear strut bar and I am just leaving out the back seatbelts, its easier that way.
Chris
MY MX-3 PICTURES
I kept mine, it wasnt a big deal, took maybe an hour at most...the seatbelt brackets were an easy 10 minutes to cut out with a dremel and a fireglass cuttingwheel. The plastic was a little more tricky, used a long driving wheel to eat away at the plastic...i tried to make the plastic contour the bar, which took some time, but if you cut a rectangular hole and dont wanna worry about asthetics, it should take long at all
