19" wheels
19" wheels
anyone ever try and fit some 19" chromes cause i went to les schwab and they said there were some that would fit,but im wondering if anyone here has doen it and had any problems?
Sacramento Raceway, CA
92 Mx3 GS
New Time 13.82 at 101.75 2.205 60ft (RIP beast klze engine)
Updated mods now... KFZE, SS Autochrome Headers and a Sweet a-- 3' Electric Cutout after it, KFZE LSD trans, Millenia manifold, KL36 ecu, Blown motor mounts, custom CAI, Custom ground wire kit, 9mm Plug wires, 2 1/4 exhaust, (Hei and MSD external coil mod), all accessories.
92 Mx3 GS
Re: 19" wheels
i doubt that they would fit and they probley would not look that good on an mx-3
Re: 19" wheels
there is 1 guy that has 19 and yea they do fit BUT WHY? truely anything after 17s isnt gonna help your performance at all, unless your going for looks, but even still its a sports car not a luxury car, if your doing looks i still say 17-18s are the way to go anything higher is just rediculus
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Re: 19" wheels
a guy here tried to put his friends 19's on his mx-3 just to see and when he let the jack out the car didn't settle the fenders were resting ON the rims and it wasn't going anywhere
now this car has lowering springs(I believe he has Intrax) and Zx2 Struts but still it would not settle
- mitmaks
Re: 19" wheels
19's will fit on mx3, not all but they will fit. id go with 17 or most 18's
Re: 19" wheels
ok so then some 18x7's will fit perfect then? With what size tire and what ofset so that they sit snug in the wheelwell after rolling the edge.
92 Mx3 GS
92 Mx3 GS
Re: 19" wheels
I run 7x18" 4x100, ET40, lowered 45mm.
No rubbing, not rolled any fenders.
215/35-18
nope-mx3
215/35-18
nope-mx3
Re: 19" wheels
Yes 19 inch rims will fit, you just have to get the proper ones, with the proper width and off set and back spacing, not all rims are the same, a stock 15 inch rim and tire has a total diamiter of 24 inches(approx) so you could put a set of 20 inch rims with a tire that only has a 2 inch sidewall and that would be 24 inch diamiter, the same as stock.
A proper tire store should measure your car to get the proper back-spacing and off-set measurements and they can tell you if they have a rim and tire comb that will fit.
Also remember, if they dont carry a 19 inch rim that will fit your car then they may tell you " sorry 19 inch wont fit on your car, but we have a nice set of 18 or 17 inch rims right here in stock" just to get a quick sale insted of sending you to a store that can get the proper sized rim, or special ordering you the proper rim.
Yes, I AM a bastard
Yes, I AM a bastard
Re: 19" wheels
yes 19" wheels will fit on your car i have a set of 19"x8 axis spyders with 215 35 19" rubber
Re: 19" wheels
I got 18*7.5, and they rubbed a bit. Just had to cut some fender out and it is fine. If I had it to do again I would not get 18s, I would get 17s. The ride is not that great, and I have to watch every single damn bump in the road. I already put a fat dent in one, and that hub is now outta whack.
