Polyurethane Suspension & Shifter Bushings Group Buy
- JdawgMx3er
Quick Question, Would the Shifter Bushings replace the Bronze Oil Bushings that you can buy off of Corksport? And how would I go about getting into this buy, can't post in the group buys section.
Re: Polyurethane Suspension & Shifter Bushings Group Buy
Nope, the shift bushings aren't the same application as the bronzoils. There are basically 3 different bushing applicatoins for the shifter. There is the bushings at the bottom of the actual shifter that connect to the shift lever-rod, and at the other end there is another pair of those same bushings at the end fo the lever/rod that connect to the shift fork in the transmission.
Thats two applications. The third (which the urethane ones apply towards) connect to the "shift stabilizer arm/rod" whose purpose is to support the shift assembly, while isolating vibration from the transmission in the shifter itself.
As for getting into the groupbuy you can email me at groharlem@hotmail.com or AIM me at GroHarlem6 if you have some questions about anything.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
