Strut Compatibility?
Justin Evans
Post by Justin Evans »
Are the GS & RS shocks interchangeable?<p>Can I use the shocks from a 323 Protoge on my MX-3, they look identical to me?<p>Please help!
Quartermaster92Y@hotmail.com
***DRIVE IT LIKE YOU STOLE IT!!!!!***
Gro Harlem
Re: Strut Compatibility?
Post by Gro Harlem »
All MX3, 90-94 Protege and 323, 91-present Ford Escort struts are identical and will work with your car.<p>But the tokico SR struts from the ZX2 have a shorter shaft which is larger in diameter, you will need to use the ZX2's thrust bearings if you use these struts. But they are easy to modify into fitting and are also metal which doesn't wear out like the stock plastic ones.
DONATE TO MX-3.COM
Justin Evans
Thanx alot, I needed the help.
