ZX2 + ST springs
Posted: April 2nd, 2003, 8:18 am
by rentd
Are ZX2 struts and Suspension Tech 1,3" springs good to use on MX-3 1,8L V-6?<p>And BTW: what are the diff. between MX-3 GS and RS? Here in Europe aren“t they marked this way. Personally i owe MX-3 Precidia 1,8L V-6. Is that GS or RS? :eek:
Re: ZX2 + ST springs
Posted: April 2nd, 2003, 8:48 am
by JasonH
The GS had the V6, the RS had the 4-cyl. The GS also had the 15" alloys, rear lower tie bar, front air dam, rear spoiler and other niceties. It came as a package. In 1995 (the last year for teh MX-3 in the U.S.) there was no V6, just a 4-cyl, but it looked like a GS.<p>Oh, and I don't know about the springs/struts for sure, but I see no reason why they wouldn't work fine. I know the ZX2 struts are good and will work, and Suspension Techniques is a good brand so it should be fine.<p>[ April 02, 2003: Message edited by: JasonH ]</p>
Posted: April 2nd, 2003, 12:32 pm
by zytariuk
I run ZX2 Struts /w Suspension Techniques lowering springs. I HIGHLY RECOMMEND this combo :) .
Posted: April 2nd, 2003, 12:50 pm
by rentd
Thanks all for infos :)
Hope i can find an on-line store where i can buy all necesary thinks at once ;) Because to send them from diff. shops will be too expensive... :confused:
Posted: April 6th, 2003, 12:04 am
by wgale
Do those who use this combo, order ST springs for an Mx3 or for the zx2? Also, How much of a gap is left above the tire after installing this combo. I heard the Zx2 strut is about 1/2 shorter, so I assume the drop is about 1.8 inches?
Posted: April 9th, 2003, 1:49 am
by zytariuk
ANSWER: MX-3<p>Also, How much of a gap is left above the tire after installing this combo.
ANSWER: The front is perfect, the rear still has a small gap...but it's noticably lowered. At least that's how it is on mine.<p>
ANSWER: You would think so, but it only seemed to help like ~.3", so i dunno :\.
