lemme give you some background info: i cut the front springs big time (had like 1.5 coils left). car looked sweet and ride wasnt as bad as ud expect but couldnt pass inspection. so i opted for Intrax 323 GTX springs. ride is alot better but I miss the tire nearly tucking. ne way some times when i turn the wheel sharply i'll hear a pop from the springs and it messes up the alightment (will pull to the left or right in regards to how i turned). i'm thinking maybe my struts got warped from when it was so low or something.what else could it be?
thanx for any replies.
spring problems.
- Shady469
spring problems.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Re: spring problems.
mine used to do that too. i THINK its just the spring settling back into place after you lift the car up with a jack. If thats what you did... for me it went away eventually so i didn't worry about it. <p>dave
when u cut the coils down from the top they get bigger so only part of the top spring hat is filled so it sits sideways. thats what mine did. only wanted to see wat 1.75 lowered would do cuz i was getting springs but i cut to much off. it was like 2.25. but yah get springs its a lot safer.
Shady, did you do an alignment job after all of those height changes? <p>one
slightly off topic but not i was driving i hit a pothole and BROKE my spring in 2!!the mech. said it happeneds but not that often its gonna cost me 817 total wit dealerships springs(123 each!) then im having them install new srtuts in the front and bearing plates (oh and labor)
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
