MX-3 ride quality
Posted: October 13th, 2002, 7:57 pm
by monkii
Hi, I had my 94' RS for years now, ride is always harsh with its stock suspension, stock 14" alloy rims...is it normal? It had been like that since the car was bought in 98'...my friends said my car handles wonderfully but I am just wondering if MX-3 is supposed to have such stiff suspension?<BR>Also, does anyone think the front seats a bit too hard? At least it's not ideal for long trip...like after few hours driving the car my butt starts to soar...
Re: MX-3 ride quality
Posted: October 13th, 2002, 8:51 pm
by Sean Mandell
Dont lower your car if you think stock suspension is stiff and Dont confuse mazdas with cadilacs.
Posted: October 14th, 2002, 3:47 pm
by tk1138
As long as you're not having trouble w/ your current set up, e.g. botteming out, you could probably get softer springs (but NOT lowering springs). '90-94 Protege springs are supposed to be a bit softer than mx-3 springs, but of similar dimension.<BR>Replacing your bushings might help a little.<BR>Tires might make quite a bit of difference depending. <P>Adding some mass to your car will reduce 'harshness' a bit, but you'll have a more underdamped system then, i.e. bouncy, as well as being lower.<P>As for the seats, you can replace them. There's info on racing seats from the main page, but those probably aren't what you're looking for. Maybe someone knows what other car seats fit in an mx-3?<P>Good luck<p>[ October 14, 2002: Message edited by: tk1138 ]
Posted: October 14th, 2002, 5:16 pm
by Sean Mandell
The seats are very uncomfortable imo. the suspension is suppose to be a little stiffer as it is a fwd sports car. but coming from an 87 rx7 to the mx-3 i could see that mx-3 is more daily driver material. [img]shrug.gif"%20border="0[/img]
Posted: October 14th, 2002, 8:48 pm
by Palofpits
Man,the stock setup is downright cushy compared to lowered and 17's.--but oh well it's the price you pay for style and handling.<BR>Anyway I always thought the stock setup was decent,are the struts still original?
Posted: October 15th, 2002, 12:32 am
by monkii
All struts and springs are stock, original size tires...ride just so bouncy...sometimes when driving over not-well-maintained road surface the interior seems going to fall apart...how do you all think about the quality of these stock suspensions compare to aftermarket parts?
Posted: October 15th, 2002, 1:30 am
by quinn_seipp
your struts could all be screwed, replacing them could be a good idea. Does it bounce after going over a speed bump? If so you may want to look into buying new struts.
Posted: October 15th, 2002, 4:21 am
by monkii
They still act as suspensions over speed-bumps, but when going over small dent or crack over road surface the impact can be felt throughout the frame...<BR>Would it be better if I replace with aftermarket dampers than getting stock parts? As I assume aftermarket performance parts would cost around the same as stock parts...
Posted: October 15th, 2002, 10:41 am
by ProtegeSTS
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by monkii:<BR><STRONG>They still act as suspensions over speed-bumps, but when going over small dent or crack over road surface the impact can be felt throughout the frame...<BR>Would it be better if I replace with aftermarket dampers than getting stock parts? As I assume aftermarket performance parts would cost around the same as stock parts...</STRONG><HR></BLOCKQUOTE><P><BR>Anything aftermarket will be stiffer.
