Suspension 2
Posted: September 15th, 2002, 7:54 pm
by SMBLOKMX3
Thanks for the previous replys when i realized i should have given you guys and girls more info. i need to lift the front end because i'm putting a 383 cui small block chevy under the hood along with a full frame so i don't want the stock springs to be crushed completly. thanks again
Re: Suspension 2
Posted: September 15th, 2002, 9:42 pm
by Hy300
I'll control myself from typing all the expicatives I'm shouting right now. In that case I recommend that you should just go with heavier springs and shocks from a Camaro and just rebuild the suspension to accommodate. You're going to be changing everything else.<P>Let me just commend you though, you're doing something I've only dreamed about.
Re: Suspension 2
Posted: September 15th, 2002, 11:09 pm
by white fish
so its going to be rear wheel drive right?
Re: Suspension 2
Posted: September 16th, 2002, 7:53 am
by lazzyie
id still take the cosmo powered mx3 dragster over a 383! 6.78 sec 1/4 was it? Nice wtf factor when you pull up to a light though, tubular steel frame custom drivestaft/rear end/everything be kinda cool to see
