Axle noise
Justin Murphy
Axle noise
I'm having a cracking and clicking noise come from my axle when I turn corners, both right and left. I have a feeling that it could be serious, has anyone had this problem and is it most likely the axle needs replacement? Could it be something else? Thanks in advance <P>J
FLYIN BY YA IN THE NIGHT!
pelado
Re: Axle noise
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by black & chrome '92 V6:<BR><STRONG>I'm having a cracking and clicking noise come from my axle when I turn corners, both right and left. I have a feeling that it could be serious, has anyone had this problem and is it most likely the axle needs replacement? Could it be something else? Thanks in advance <P>J</STRONG><HR></BLOCKQUOTE><P>No one's ever had this problem before.<BR>Did you try searching this board?
Brainless
Re: Axle noise
I'm having the same problem right now. I'm goona have it checked as soon as a have a minute.<P>I get that noise at low speed when I do sharp corners. What about you?
Jonathan Michaud
93 Red RS
93 Red RS
ProtegeSTS
David Coleman
Re: Axle noise
remanufactured axles are like $60USD or so.
David Coleman
Justin Murphy
Re: Axle noise
Thanks guys, I'll have it checked out. Yeah it makes the noise when I go slow around corners. The CV joints would cost about how much? <P>J
ProtegeSTS
Re: Axle noise
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by David Coleman:<BR><STRONG>remanufactured axles are like $60USD or so.</STRONG><HR></BLOCKQUOTE>
-93 MR2
#129 E-stock
#129 E-stock
