STRUTS OR SHOCKS
STRUTS OR SHOCKS
WHAT CARS SHOCK OR STRUT CAN BE INTERCHANGED WITH THE MX-3, MAYBE THE MX-6 OR THE 323<P>PLEASE IF ANYBODY KNOWS IT WOULD BE GREATELY APPRECIATED<P>I WANT TO PUT KYB AGX SHOCKS ONTO MY CAR<P>OR IF U KNOW SOMETHING SIMILAT TO THE KYB AGX PLEASE TELL ME
Jesse<BR>red 92 gs
ProtegeSTS
Re: STRUTS OR SHOCKS
KYB doesnt make the AGX for the MX-3 or anything interchangeable. If you want adjustables, youve got the Mazdaspeeds, or koni inserts.
-93 MR2
#129 E-stock
#129 E-stock
ARE THE KONIS COMPARABLE TO KYB AND OR ARE THE MAZDASPEED ONES BETTER IN YOUR OPINION AND IF YOU KNOW OFF THE TOP OF YOUR HEAD WHAT ARE THE PRICES ROUGHLY<P>THANKS
Jesse<BR>red 92 gs
pelado
Don't type in all caps.<BR>Look at the Corksport website.
ProtegeSTS
ALL CAPS ARE BAD, as it means that you are yelling, and its hard to read....so like pelado said, please dont do it.<P>The konis are rebuildable, and very high quality. They are only rebound adjustable, while the Mazdaspeeds adjust both compression and rebound.<P>Both the Mazdaspeeds and Konis are better than the AGXs.
-93 MR2
#129 E-stock
#129 E-stock
thanks and sorry about the caps<BR>i think i will probably go with the mazdaspeed ones cause they give me more adjustment,<P>thanks again for the input
Jesse<BR>red 92 gs
