CV Shaft/Joint Warnings
Posted: May 27th, 2002, 6:30 am
by JCali
Hey List<P>When CjThor lowered my car...which looks awesome...he noticed that my cv shaft was shot...I special ordered the shaft through Kragen they told me it would take 8 days...Jarid hooked me up with a contact. So we get the joint...We can't get the damn thing off...It was rusted so much it never budged after a air-hammer. So I took it to a shop...They want to charge me $250 USD in labor...cause it has to be taken to machine shop to press it back together. It pisses me off, but what can you do. Just a warning watch out for rust when buying a mx-3 and CV joints <P>JCali
Re: CV Shaft/Joint Warnings
Posted: May 27th, 2002, 10:41 am
by OsoSlo z28
i'm curious as to what has to be pressed back together.
Posted: May 31st, 2002, 3:15 am
by Gro Harlem
are you talkikng about the hub nut? If you take the air hammer to the nut long enough, it should break free. I had to sit there for like 4 striaght minutes before the sonabitch came off.<P>BTW: i'm doing a "how to" for changing the axle on my site, I'll post the link when i'm done. It'll have pictures nad procedure for the passenger side axle. It is for a mazda protege, but the procedure should be the same.
Posted: May 31st, 2002, 8:56 am
by Gro Harlem
I just finished doing my axle and writing the how-to. HEre is the link...hope it helps you out<BR> <A HREF="http://mazdaprotege.net/tech/howto/rightaxle/" TARGET=_blank>http://mazdaprotege.net/tech/howto/rightaxle/</A>
Posted: May 31st, 2002, 2:11 pm
by Ogimoj
Get some WD-40 (or equivilant) in there and let it sit for a while. Air hammer some more and it should break free.
