need ecu and safc wiring diagram, 93 gs.
Posted: September 25th, 2004, 7:56 pm
by Dali
hey, ive looked and cant find what i need so... does anyone have the wiring diagram for the apexi safc, i will be hooking this up in my 93gs with the klze motor and kl36 ecu. is there anything else i should look out for. thanks for the help.
<small>[ October 02, 2004, 06:33 PM: Message edited by: Dali ]</small>
Re: need ecu and safc wiring diagram, 93 gs.
Posted: September 26th, 2004, 8:38 am
by cozmo959
thats the same exact set up i have....i spliced the afc 2 into my ecu...i just used the wiring diagram in the manual. try look on the apex website they have pdf files of instructions
Posted: September 26th, 2004, 9:02 pm
by mdavis
So is it true SAFCs don't work at WOT?
Posted: September 27th, 2004, 12:48 am
by Josh
from what im told is thats all they work at, on a Mazda is WOT.
Posted: September 28th, 2004, 2:34 am
by Dali
k got the unit in today, it came with the manual's, now does anyone have the wiring harness diagram for a 93gs so i can hook this thing up
thanks.
Posted: October 2nd, 2004, 7:34 pm
by Dali
still looking for both wiring diagrams, thanks.
Posted: October 2nd, 2004, 8:30 pm
by Dali
k i think i found the wiring for the safc
red=power
green=engine rpm
gray=throttle signal
black=ground
brown=ground
yellow=airflow pressure siganl output
white=airflow pressure signal input
wire not used are the pink, orange and blue. i think this is right, just need the wiring for the ecu now, the pins and colors, thanks.
Posted: October 4th, 2004, 9:38 pm
by Dali
somebody has to know how to hook this thing up. have to get it done by the end of the month. thanks.
Posted: October 7th, 2004, 9:21 pm
by Dali
i will pay someone for this info
i need it soon, thanks. email me at
unclesluggo@shaw.ca
Posted: October 8th, 2004, 12:04 am
by Grants
Sent an email - hope it helps
Posted: October 8th, 2004, 8:21 pm
by Dali
hey thanks for the email, hope it helps, color codes are different from the diagram and the ones coming out of my ecu though. should be able to figure this out but if anyone knows which wires go where email me. if i dont fry my car i think i will do a write up so no one has any problems in th future trying to hook up a apexi safc.
Posted: November 13th, 2004, 7:18 pm
by Dali
well, still looking for this information. help.
