I want to turbo my geo tracker!
Franko
Post by Franko »
I was thinking about it alot and I dont think that it would be too hard to turbo the geo tracker that I own. I know where there is a 89 323 4 door at a scrap yard that has the b6t in it.. I was thinking of mabey taking the turbo, manifold and intercooler out of the 323 and see if it could fit on the 1.6 sohc in the tracker. The thing does have 277,000 km on it but it is still strong.
You see, I have noticed something about when you have a car that is turbo.. Once you have driven a car that is turbo you want everything that you own that runs on gas to be turbocharged. I am actually looking into a turbo or supercharger for my t-maxx. :p Anyways, I only drive the tracker in the winter time but it would be so so great to have it boosted.. I would only run about 5 psi.. I am pretty sure that it would be able to take it. It probally uses a map sensor so I could use the safc2 that I have to work with it.
Any ideas? Also if anyone has some pics of the b6t turbo and manifold I would really appreciate it.
<img src="http://memimage.cardomain.net/member_im ... 3_full.jpg" alt=" - " />
What
Re: I want to turbo my geo tracker!
Post by What »
b6t manifold won't fit. But you can certainly run more than 5psi and have some fun.
My partner in crime and I have spent a lot of time on Suzuki stuff. Mazda BPs aren't the only good 4 cylinders of the era. :) He's based in Quebec, but I'm in Calgary.
http://www.turbinetech.ca
I assume you have G16 16 valve?
example of Turbine tech equal length stainless manifold and kit on Swift G13B.
<img src="http://www.teamswift.net/~kyle/images/FMIC.jpg" alt=" - " />
Return to “Forced Induction”
