Preparing to TURBOIZE...
manowar821
Okay, I've decided to save for a turbo kit for my SOHC 1.6...
Mnemonic
Re: Preparing to TURBOIZE...
you wouldnt need to use high octane i would just use 93-94octane as for tranny i would go ahead and do a manual swap that away you dont have to worry about can the autotranny take the increase in power. and as for have to worry about knock running that low psi i would worry to much but just remeber there can always be a problem with a motor that wasnt design to use a turbo
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- Limegreen mx-3
from the sound of it are u getting the turbo kit from racingmazda. am from San Antonio rick the guy how made turbo kit his mx-3 was fast. i think u should go standard fun to play with. latersOriginally posted by manowar821:
Okay, I've decided to save for a turbo kit for my SOHC 1.6...![]()
Drifter MX-3
The 1.6 turbo kit that was on my car was putting down some good numbers. I didnt own the car back then so i cant tell you to much about it. the transmission decision is basically up to you, just depends on what you prefer to drive. knocking definetly wont be problem. Ric has pulled over 300hp on a 1.6 that was completly reliable.
92 MX-3 RS,
Racing Mazda turbo kit. 451 WHP @ 25 psi
12.1 @ 117 mph w/318whp
http://www.cardomain.com/memberpage/652555
