Page 1 of 2
S-AFC idea
Posted: January 16th, 2004, 5:51 pm
by Marlon
i was thinking about why the s-afc won't work well on out cars(cause when in wot it has a preset fuel map) and i was wondering if anyone has tried running a safc but not letting the stock ecu know that your are at wot, only letting the safc know, so then u can still have 2 different fuel maps one for crusing and one for wot
would this work
Re: S-AFC idea
Posted: January 17th, 2004, 9:45 pm
by Marlon
anyone
Re: S-AFC idea
Posted: January 17th, 2004, 11:46 pm
by maldo
That is the reason it doesn't work effectively with "our" cars. The TPS is an on/off version, it does not provide a signal for anywhere in the middle of the on/off signal. So in effect, the low throttle setting is anything that is not at WOT, high throttle setting is only at WOT. A remedy to this, and a mod that many have started to do is to remove the TPS as the actuator and replace it with a MAP sensor. A MAP sensor will give you the low throttle setting for essentially all stages under vaccum and high throttle setting for everything under boost.
Here is a tech article for the mod:
Fooling the S-AFC
I hope this is what you were getting at, if not, clarify and I will try to help further.
Re: S-AFC idea
Posted: January 18th, 2004, 1:00 pm
by cjthor
When I go to the monitor part of my AFC I see more than either a 0 or a 100 percent. It is not just an on or off thing. Maybe the DOHC guys dont have this problem? I sure dont.
<small>[ January 18, 2004, 12:05 PM: Message edited by: cjthor ]</small>
Re: S-AFC idea
Posted: January 18th, 2004, 1:41 pm
by maldo
When you go and monitor the input voltages, what voltages are displayed for the TPS? You should see approximately 0V and 5V. Possibly the DOHC versions had a TPS with variable voltage, in that case the S-AFC would work as it is supposed to. Not sure why yours would have a variable TPS when not even the Miata came with one.
Re: S-AFC idea
Posted: January 18th, 2004, 1:57 pm
by cjthor
Almost positive its variable. I will check today.
Re: S-AFC idea
Posted: January 18th, 2004, 2:10 pm
by Marlon
the S-AFC only has 2 fuel maps right
so then why do you need variable tps?
Re: S-AFC idea
Posted: January 18th, 2004, 3:22 pm
by maldo
The simple on/off TPS that the MX-3 has will provide the low throttle fuel map for all conditions other than WOT which is when the high throttle map takes over. Essentially then, 99% is covered by the low MAP and 1% is covered by the high MAP. The benefit of the variable voltage TPS allows blending, meaning that when you set your S-AFC to have the low map for all voltages 80% or less of the max voltage it will do so, likewise 20% of max voltage or greater will be the high map. It will allow better tuning under acceleration.
Re: S-AFC idea
Posted: January 18th, 2004, 6:43 pm
by monty73741
u know.....
i saw an article where they converted a miata maf to map, but superstreet doesnt have on there site anymore, i was thinking i could be done on the mx-3...i might try when my mx isnt a daily driver anymore
Re: S-AFC idea
Posted: January 18th, 2004, 6:52 pm
by cjthor
Ok for all you guys with an afc. When you are on monitor mode what does your throttle percent show...does it progressively go up or is it just 0 and 100 percent.
Re: S-AFC idea
Posted: January 18th, 2004, 10:52 pm
by maldo
0 or 100%, never in between.
FYI, the Superstreet conversion from MAF to MAP was with the installation of a FM link.
Re: S-AFC idea
Posted: January 18th, 2004, 10:57 pm
by cjthor
FYI guys the DOHC TPS is variable. 0-4.5 volts.
Re: S-AFC idea
Posted: January 19th, 2004, 12:51 am
by maldo
Lucky for you.
Re: S-AFC idea
Posted: January 19th, 2004, 4:23 am
by monty73741
yeah i know that the link was for a fm link.....
but would the conversion be possible in the mx
Re: S-AFC idea
Posted: January 19th, 2004, 8:59 am
by BATTOSAI
In my Gs the TPS voltage raises progresive and accurate, and the S7afc works on Wot or partial. It has been shown on my A/f ratio gauge!
