What´s the best way to disable EGR?
BATTOSAI
Post by BATTOSAI »
I think that disabling the EGR would be great on a Turbocharged engine, as when it´s open, the exhaust backpressure spinning the turbine decreases for sure! I heard about bolting a plate on the exhaust manifold (Kl-ze style) and leaving all the system untouched, but I don´t know if it would cause any CEL. Any other suggestion?
European Mx3 GsRT
mazdasly75
Re: What´s the best way to disable EGR?
Post by mazdasly75 »
You may 3 things:
-put a dime in between the gas recirculation conduct. This will block the gas passage and the EGR still fonctional. No cell.<p>-Install ZE ecu. No need to hook the EGR anymore.<p>-or like me buy a stand alone fuel management.<p>The first above is the cheapest way to do the mod.<p>But, you know the EGR is shutting off at 75% TB opening? :shrug:
1996 MX3, KL, stock internal, T3T4, 10psi, tial wastegate and blow off, 450cc injectors, 255lph, 3" mandrel bend exaust, 67mmTB, megasquirt II, launch control/flat shift, boost controler, 4bars MAP 16x16 built in, 300whp
BATTOSAI
Post by BATTOSAI »
yes, but with in my turbo I had to put the turbo quite far, what results on a laggy turbo boost response! I think that it may help a bit!
European Mx3 GsRT
Bri94GS
Post by Bri94GS »
When an mx-3 is at wide open throttle, doesn't the EGR automatically shut off?
~Bri - Morph860@aol.com
'94 MX-3 GS (FOR SALE!)
'04 Mazda 3s 5-door
zoom-zoom
Buff1110
Post by Buff1110 »
egr is off at wot
Dan
02 Tacoma TRD - Daily
Hy300
Post by Hy300 »
What TPS voltage does the ECU interperet as WOT?
Bri94GS
Post by Bri94GS »
I beleive 4.5
'04 Mazda 3s 5-door
zoom-zoom
UnkleDuke
Post by UnkleDuke »
Sorry if this sounds ignorant, maybe I've heard the non-abreviated term...What is EGR and TPS?
No Sig
Bri94GS
Post by Bri94GS »
TPS = Throttle Position Sensor
EGR = Exhaust Gas Recirculation
'04 Mazda 3s 5-door
zoom-zoom
JJ
Post by JJ »
what does the klze do with the exhaust gases since it doesnt use an EGR??
Custommx3
Site Administrator
Post by Custommx3 »
Seriously... Your exhaust pipe :)
JJ
Post by JJ »
lol
Bri94GS
Post by Bri94GS »
No way
'04 Mazda 3s 5-door
zoom-zoom
papa roached
Post by papa roached »
d00d! this has plauged man kind for centuries :p
Return to “Forced Induction”
