hey nos q
MI-Archangel
hey nos q
hey guys im just wondering can nos blow u to pieces? Like is it safer then the movies make it look. I mean its good hp but i dint wanna blow my engine or myslef up. also their is wet and dry whats the diff and how much of a shot should i get?
Re: hey nos q
Ok Mike yes Nitrous can blow up your engine quite literally in the right frame, however it can be used safely if you have a well maintained, well running motor. I would suggest going no higher than a 50 shot on your stock fuel pump. Ok as for types:
Dry- Just Nitrous
Wet- Nitrous and Gas mixed(usually safer)<p>Now don't say NOS its called Nitrous Oxide. NOS is actually Nitrous Oxide Systems a company owed and operated by Holley.....<p>[ June 20, 2003: Message edited by: lazzyie ]</p>
Dry- Just Nitrous
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
MI-Archangel
Re: hey nos q
ya i know that but most people don't so i dumbed it down lol
thanks for the info.
Re: hey nos q
i am running a 50 shot dry, and i haven't had a problem yet, just use it right make sure your running rich, and have a good fuel pump. if used correctly its no less harmful than any other forced indcution
Turbo 2.5l mx3
