Car cuts out past 10psi?
Posted: May 11th, 2003, 2:02 am
by cjthor
Just as it says. Anything past 10 and the car cuts out/over revs. My shift light comes on and the car just bogs and has no power. Any ideas?
Re: Car cuts out past 10psi?
Posted: May 11th, 2003, 4:53 am
by natural born honda killer
fuel inj maxed out maybe???
Posted: May 11th, 2003, 6:24 am
by cjthor
Thats kinda what I am guessing...but why the shift light kickin on? I have it set for 6200rpm and im not even close...maybe 5500 when it goes off and the engine starts to cut.
Posted: May 11th, 2003, 11:00 am
by boostedmx
where is your tach hooked up to? sounds like ignition. if your hooked up to a coil, it may be failing. sounds like ignition to me though. dont know of anything else that could send a fase signal to the tach and make the car cut out. so start there. maybe msd of some sort?keep us posted.
Posted: May 11th, 2003, 1:45 pm
by Hex3
i just helped one of my friends put his turbo on and its doing the same thing, he has a fuel regulater and everything but it still cuts off after like 5000-5500 is your fuel thats what we thing it is he hasent upgraded his fuel rails they are stock 2.5 GT rails. After that i dont thing he should have a problem. Go on
www.probetalk.com post on there and make sure but thats what we thing is the problem with his... On the shift light going off when the car dies i really dont know did you hook up your shift like to Tack yellow/blue wire at the distributer? and run a constant 12V from Batter and get a good ground.
Posted: May 12th, 2003, 4:28 am
by cjthor
Well I am pretty darn sure its fuel. Maybe the fuel cuts out due to the injectors getting maxed out. Puttin in a set of 370cc as we speak.
Posted: May 12th, 2003, 6:37 pm
by boostedmx
why is it causing the shift light to come on? cutting out would be a different story all together but, to through some whacky signals out is what led me to believe it was ignition. unlees the tach is messed up. oh well , let us know
Posted: May 13th, 2003, 3:45 am
by cjthor
Well I had the injectors already so that is why they're goin in. I'm also taking out all the egr stuff and wiring while I am at it. Think I am gonna go with MSD SCI but not all sure how to install....
Posted: May 13th, 2003, 3:57 pm
by 92RedMX3
Well here is one idea, do you go lean at that point? If you have a A/F guage then you'll know and if you start getting a lean condition then thats gonna be your problem. If it not getting a lean condition then i would say that your ignition just cant get it there. Now, Can you turn down the boost and it work properly?
Posted: May 17th, 2003, 2:10 am
by cjthor
Just an update. I added my injectors and played with the AFC. No more funky cut and no more shiftlight. I can safely boost past 10psi now! Went up to 12 without a problem!
