wiring apexi s-afc
wiring apexi s-afc
I have a 1994 1.6L DOHC manual transmission. I'm trying to wire up my apexi s-afc but I don't know where all the wires tie in to my ECM. So far, I have power. I used an DVM to find a 12 VDC power source and then a ground. I plugged back in my baterry and the Apexi came on and so did the cooling fan, never worked before though.<P>Anyway, as for the RPM/pressure sensor, the online manual doesn't show one but it does show a vehicle speed sensor and two different mass airflow signals.<P>Does anyone know how to wire one up and what would the settings be after that? Any help would be greatly appreciated!!!
Re: wiring apexi s-afc
Dude, you need to search this site this has been discussed in detail, and the schematics are here as well, by the way good luck if you ever get it to run right with your ecu.
94 Mazda MX-3 BPT Custom Intake/Exhaust T3/T4, 51mm BOV, Tial WG, 2.5" Piping, 880cc Inj, Godspeed Intercooler, TEC II
My MX-3 Website
My MX-3 Website
