programmable ecu
Posted: February 13th, 2002, 9:44 pm
this is for those with a dohc thinking of doin a swap. the s-afc is next to impossible to hook up so i asked derrick to check on the possibility of chipping the mx ecu. he had one sent to him and he checked it out. you can have any fuel map (bpt,b6t,etc.) put on the ecu. this way you won't have to worry about timing or air/fuel ratio cause it will run like it's from the factory. it costs about 260-270 and then you send your ecu back to them(i think). oh well, just letting those of you doing swaps know that there's another route to go.
