Re: Blow Off to Atmosphere w/ B6T
Posted: January 12th, 2002, 3:42 pm
by cjthor
I got the same BOV. Can I install it the same way you did using my stock MAF sensor? Mine is a DOHC by the way..94
Posted: January 12th, 2002, 7:24 pm
by maldo
Keep an eye on your A/F ratio when the bov releases pressure. The biggest problem with the stock setup is without remetering the air the motor has a tendency to go rich. You should be able to compensate with the S-AFC.
Posted: January 13th, 2002, 3:42 am
by marshmallow15
wow! so you actually got the bov whoosh sound without a turbo? or do you have turbo?<P>i was wondering if you could hook up a bov to an air intake so it gives you a little permanent "whoosh" effect...iono. seems ricey if possible?
Posted: January 13th, 2002, 3:49 am
by marshmallow15
007, could you kinda simplify or make it a little easier to understand? sorry. it's just some terms i can't recognize.
Posted: January 13th, 2002, 2:53 pm
by David Coleman
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by marshmallow15:<BR><STRONG>007, could you kinda simplify or make it a little easier to understand? sorry. it's just some terms i can't recognize.</STRONG><HR></BLOCKQUOTE><P>He has a Turbo<BR>The T in B6T means turbo.
