Intercooler Piping help
- cjthor
Hey guys,<BR> I was looking under my hood for a way to run the intercooler piping and found that there is little room to route it. Does anyone have and ideas or pictures of routing?<BR>I am sure someone with a turbo on this board can help me. thanx!!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
maldo
Re: Intercooler Piping help
If you have a side-side intercooler you can do what I did. Run the pipe off the turbo behind the driver's side headlight, through the thin sheet metal(requires cutting) and in front of the rad. The pipe off the TB goes to the passenger side, remove the windshield wiper resevoir, through the sheet metal and in front of the rad. Any way you do it is going to be a tight fit.<P>You can rewire the rear windshield bottle to run the fronts. I don't have much pressure but will probably change the pumps to solve this problem.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
renef
can you send me a pic of the intercooler? I need to see how you mounted it.<P>I'm stuck and don't want to re-invent the wheel.<P>thanks.<P>RF
White 1992 MX-3 RS Turbo<BR>"Live Boosted or Die!"
