Turbo w/o Intercooler
What would happen if you didn't install an intercooler with your turbo? will it blow your engine? Thanks
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: Turbo w/o Intercooler
it would overheat cause there isn't anything to lower the temp. so in the long run...it's possible
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Yea...it's not something i'd recommend
- cjthor
Well..... If you really think about it, Chevrolet used to put out the 3.8v6 with no intercooler for about four years or so. Never had a problem with it either. So it all depends on how you have it set up. <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Bri94GS:<BR><STRONG>Yea...it's not something i'd recommend</STRONG><HR></BLOCKQUOTE>
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
It was a carbeurated engine though, wasn't it?
- cjthor
Yes it did have a carb. The engine usually ran about 210 degrees. I had a turbo vega with a v6 and had no probs with not having an intercooler. Just didt get as much hp. <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Bri94GS:<BR><STRONG>It was a carbeurated engine though, wasn't it?</STRONG><HR></BLOCKQUOTE>
Jarid Perry
The reason they put turbos in some of those cars is to make up for displacement or engine size. Instead of throwing a v8 in there, they put a turbo 6....you could run a turbo with no intercooler, but if you're going to use the turbo for performance, or run a lot of boost, you should def. have one big enough to keep things cool
Most companies use the turbo to get the best of both worlds. On one hand, you can have a small engine (easy to put into small cars and it also weighs less) which gives you great MPG. Yet at the same time, using a turbo, will give you more power (also does not take up much space...and does not weigh much). So turbocharging a small engine is a better alternative for car makers than using a larger engine.
Having a smaller engine usually gives the car a cheaper insurance rate too...making it appeal more to some buyers...v6's are a lot cheaper than 8's on insurance
The basic idea of an intercooler is to cool the intake temp since when the turbo compresses the air it also heats it. HEAT=BAD=POWERLOSS. By cooling the ambient intake temp it allows you to run a higher boost pressure without causing detonation.
Without the IC, the turbo is limited in power to avoid overheating.<P>It's a common thing to have cars run without an IC. It's veray easy to add even a small one.<P>Makes a HUGE difference in power.<P>RF
White 1992 MX-3 RS Turbo<BR>"Live Boosted or Die!"
