Gaps on my new clear signals (pic)
I just bought these signal lights from procarparts.com and there are some large gaps between the lenses and the housing. Im just wondering if anyone else that bought clear signals experienced the same. If so what did you use to seal the gaps with? I cant really tell if these gaps will cause a problem with my lenses down the line.
<img src="http://www.elitehq.net/joe/IMG_0033.JPG" alt=" - " />
Black 94 RS, Erebuni MS style front, OEM sideskirts, Clear signals, altezza tails, 93 seats, Civic projectors
- GregoryChristian
Re: Gaps on my new clear signals (pic)
SEAL THEM WITH SOME CLEAR SILICONE JUST TO BE SURE ABOUT ANY MOISTURE ISSUE ......
** My MX-3 ** http://www.cardomain.com/ride/360367
Thanks greg! Ill give it a try
....did anyone else recieve their signals with gaps as well?
Yup, same here. Was kinda irritated about it til I pulled the factory stock orange ones and saw they also had a similar gap at the ends. Been debating about adding sealant before install. Looks like the reflector area is sealed against the lens surface(both on stock & clear aftermarkets) by a bead of sealant that is inset from the outer edge of the lens. My concern tho is that even if the reflector space is already adequately sealed, that gap near the edges will allow dirt to deposit over time and make the clear lenses look dirty. My orange ones seem to have some dirty deposits behind edges so guess additional sealant makes sense.
I just bought the lenses from corksport, just fill the gaps with silicone like Gregory said. That's what I did, filled em almost to the edge. Wasn't takin any chance after all the hassle I had with my altezzas. Once you get some moisture in there it can be a pain to get rid of all of it so make sure they're sealed good and tight before you use em.
- papa roached
are the smaller light openings cut open to be used or are they filled like the stock ones
I just installed them the same as my stock lights.
~Tyson
~Tyson
My Car Domain Page:
http://www.cardomain.com/memberpage/496099
Take a Look, leave a comment, and don't forget to vote.
Yea, there is a circular cutout that you can just push in, does anyone know what those smaller light locations are for? ...or what they can be used for?Originally posted by papa roached:
- papa roached
they are for the DRLs that other countries got, the USA didnt use them
THey will turn nice and mossy green over time. Make sure when you seal, also seal around the mounting screw at the front, ot dab a bit onto it when you are putting it in, this way you eleiminate a direct way for the water to get in there (past the screw).Originally posted by Joe's 94 RS:
Wow, I never thought of that. I sealed everywhere else tho. Thanks for the tip man.Originally posted by JDM:
