Anyone running 225/50-15?
Posted: April 17th, 2004, 2:02 pm
by cjthor
Looking to get a set of drag radials on a 15x7 rim with a 38mm offset. Anyone running the same size wheel and tire? Help!!
Re: Anyone running 225/50-15?
Posted: April 17th, 2004, 9:37 pm
by curtklze
I have a set of BFG drag radials on stock 15X7 GS rims and they fit fine.
Posted: April 17th, 2004, 10:51 pm
by cjthor
But what size? 205 or 225? and what is the offset?
Posted: May 3rd, 2004, 12:19 pm
by rayrrod
i am running 225 50 15 on the front and 205 60 15 on the rear. do not even know what offset means much less know what it is.
i could not find more than 2 tires 225 so only bought 2.
am now looking for 18s since i got 18 rims
Posted: May 3rd, 2004, 11:14 pm
by Taras
I used to run 215/50/15 on stock rims. I know it is smaller than stock, but fit no problem.
Posted: May 5th, 2004, 11:07 pm
by lstpier
Do run 225/50/15 Toyo RA-1s for the track on 15x7 35mm offset wheels. There's 7mm of clearance to the coilovers. Without the 450lbs rear springs I got I'm sure tire would rub on the fender's lip (but front end is your only concern on a drag car).
<small>[ May 05, 2004, 10:10 PM: Message edited by: lstpier ]</small>
Posted: May 8th, 2004, 1:44 pm
by curtklze
I run 225-50-15 on the stock GS rims, what ever size that is, I dont know what the stock off set or back spacing is.
