removing old seats
removing old seats
im having problems removing my stock seats. the bolts seem to be rusted on. anysuggestions on how to get them out. thanks-
*Girls can go fast too!*
Re: removing old seats
ya i took my passenger seat out and they all came out no problem besides the one closest to the door.. but i used some liquid wrench or somin of the nature to losen bolts... then i used the 17 i think it is.. but kept sripping it.. so then i took a cuttin tool and cut the bolt head in half and usd the gaotr grip came right out.... but just try using some liquid wrench and the gator grip, people say that the gaotr grip is junk it has worked wonders for me
<img src="http://images.cardomain.com/member_imag ... 2_full.jpg" alt=" - " />
how close are you to madison???
- monty73741
i used a METRIC socket with a breaker bar
Jason Danaher
Please Help Support MX-3.com
thanks for all your information..i think it will help a lot and this is for SAMM..im about 30 mins from madison.
breaker bar should work just fine...mine were all new looking. I was amazed and so was my friend. On a 93, seat bolts with no rust...
Tom Alexander
still having problems removing the seats..where can i find liquid wrench at? i went to autozone and they didnt even have it!!!i was so shocked and pissed cuz i need these seats out..
spray with wd-40. loosens rust and bolts. One of the greatest tools invented. nest to duct tape of course.
mine were rusted right to the brackets so i just used CLR and vice grips.You have to clamp right in really hard. had to buy new bolts tho, and they were damn expensive so try to salvage yours unless u want to spend 15+ dollars on new bolts.
Splixer
Haha...I used my boyfriend! I know, going against the whole girl power b/s but it worked great!
Kenzie
Kenzie
::'94 MX-3 GS::KLZE::
- MX3-Freak
Just get a torque wrench and get them off...will come off with ease (the bar is 3x longer then a regular ratchet). Plus you can actually get the correct bolt tension when you replace them instead of just making it as tight as possible...
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
