CF Hood w/out hood pins
Posted: December 21st, 2003, 4:05 am
by Low3-XM
Is there a way where u could screw you stock hood latch on-to your CF hood ???
Re: CF Hood w/out hood pins
Posted: December 22nd, 2003, 12:01 am
by acid_mx3
even if you could the wind will get under yout hood and lift if right up the latch isn't strong enough at all.. you are a thousnd times better off with just buying some hood pins and calling it a day
Posted: December 22nd, 2003, 12:56 am
by monty73741
u know it works on the stock latch...
the hood pins are ther efor safety....
u can install it with out pins but dont ***** when u crash ur car...ask jarid what happens when u dont use pins
