help!!! WITH SEATS
Guest
help!!! WITH SEATS
Post by Guest »
I need to take my seats out of my car does anyone know how?
Sam Baker
Re: help!!! WITH SEATS
Post by Sam Baker »
easy.. i've done both seats actually, since i mounted my amp under the passenger side one, and i disconnected the seatbelt thingy on the driver's side. so! anywayz there are 4 big bolts at each corner of the seat. i think they're around 14mm in size, so get a big wrench and take them out! the rear bolts are covered by plastic, so remove those and unbolt. easy as that! hope dis helped
~ sam
92 Autozam AZ3
Guest
Post by Guest »
thanks
Andrew_Pakula
Post by Andrew_Pakula »
Yea its just 4 bolts, you don't even have to touch the seatbelt.
If the bolts are rusty though it might be a little hard. I had one bolt that was really stuck bad, had to take it to a mechanic and he worked on it for a few minutes and finally got it off.
Guest
Post by Guest »
how do u get teh plastic pieces off?
kuruption1983
Post by kuruption1983 »
you g2 be kidding us that you cant take the plastic pieces off. :D
First off, i wanna know why you took them off, second of all, one suggestion while doing stuff on your car, Don't be gentle !!! just pull the damn thing off, and dont worry they wont break.
Sam Baker
Post by Sam Baker »
LOL actually i've broken TONS of those lil p.o.s. black push-in things.. they are so cheap! but anywayz.. the plastic pieces covering the bolts for the seats have screws on top, so unscrew them! and then they have just some black piece, and like kuruption said, have no sympathy for these things. i was scared to pull it off at first, but USE FORCE! screw driver.. hammer.. lol just slide them off. or pop em! hope dis helpz ya
~ sam
92 Autozam AZ3
rancid420potheadpunk
Post by rancid420potheadpunk »
the little plastic things are a total POS and they suck so badly, i hate them, if anybody has any they want to get rid of tell me i need about 20 or so (cause i'll break a few more)
Casino
Post by Casino »
man i hate the pop peices in or cars i break then all the time no matter how carefull i am. but what can u do i guess :shrug:
http://www.realtimeperformance.ca
03 miata, formally bottle fed 96 DOHC
i broke 2 more of them today.
Guest
Post by Guest »
well i got the plastic pieces off but guess what im too weak to get the bolts off
pipes
Post by pipes »
I suggest you use a socket. If you are using one and you still cant get it off, get a peice of hollow pipe and put it over the handle end of the socket. This will give you greatr leverage and make it a piece of cake.
Goodluck.
i had to do that to remove the lugs off of my front wheel. i got a quick question. who ever had my car before put the security lugs on the two backs wheel but not the front ones, how do i get those d@mn things off and can a tire place remove them if i cant?
mx34u2nve
Post by mx34u2nve »
most tire places have a little kit that has a whole variety of different size locks. so you should be able to get them off unless its a really unique lock.
Turbo 2.5l mx3
nope-mx3
Post by nope-mx3 »
Just use a pipe that`s tight enough to get hammered onto the lug nuts, and just use some airtools to get it of. Had to do that with my 4 lock-nuts... Damn mechanics lost my security-key...
nope-mx3
Return to “Appearance”
