painted caliper?
mx34u2nve
painted caliper?
Post by mx34u2nve »
has anyone painted here calipers???how did you do it?? did you tapoff the rotor. or did yu takethe caliper right off. didyou use the actual calipr paint or could you find some cheaper stuff
Turbo 2.5l mx3
mitmaks
Re: painted caliper?
Post by mitmaks »
i've taped off everything, wiped grease and brake dust, if you get some paint on rotor dont worry, it will come off first time you hit youre brakes
papa roached
Post by papa roached »
i took mine, wire brushed them with a brush on a drill, then i sprayed them with breake cleaner and let them dry and i painted them, used cliper paint, i pulled mine off to do it though
Spydie
Post by Spydie »
I bought the Foliatek Calliper paint. $50 CDN a can. comes with brake cleaner and hardener. You apply it with a brush....Pricy but lifetime warranty. resists heat, chemicals.
mdavis
Post by mdavis »
I asked everything else off, fine wire brushed/steel whool'd them and then used SPECIAL brake caliper paint. I head normal paint can flech off easily and can become permanently discolored by brake dust.
GS-R SE
Fixin's
Return to “Appearance”
