Does anyone know if there's a green spark plug wires?
Hi all. as my topic says. If someone can please tell me if this stuff exist? I want to get one but can't find any.<p>thanks in advance
- millionflame
Re: Does anyone know if there's a green spark plug wires?
I can't remember the exact brand, but if you go to the Nopi.com store they have some there. You just have to search the ignition wire section.<p>As far as I know, there is only one brand as I have searched very hard for the same thing.<p>~A<p>Here, I just searched and this is the link.<p>VITEK Braided Performance Wires 4cyl 1.6L GREEN $128.71<p>VITEK Braided Performance Wires V6 1.8L GREEN $138.68<p>Green Wires<p>[ July 20, 2003: Message edited by: Aiden ]<p>[ July 20, 2003: Message edited by: Aiden ]</p>
~ Millionflame (94 GS 120K)
Thanks Aiden...appreciate it.<p>Holy, didn't expect that it'll that expensive. But I like it though. Maybe few months from now I'll get them.
Can't you just find some high-temp flex loom and use that over the stock stuff?<p>http://www.wirecare.com/wc_product_list.asp?prod=PT&prodline=ES
hey..that's a good idea too. thanks bro
- millionflame
Wire loom works great too, but IMO it does not look anywhere near as good as an ACTUAL coloured wire.<p>Loom is much much cheaper though, so you could do that until you decide to get those wires.<p>~A
Yeah that's what I possibly do Aiden.<p>thanks for the help guys.
loom looks crappier, but another thing you can do is get some green silicone hose from NOPI, cut a slit all the way down the hose and slip it over your existing wires (or upgraded wires of whatever color).<p>Looks like they are supposed to be that color, and looks much cleaner than loom
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Deleted
I don't think heat shrink would work well with all that heat under the hood. I said flex loom because that stuff is rated up to 450 degrees Farenheit.
